Rytec.be EPG ja Newnigma, testaa
www.rytec.be -> epg for newnigma2 unstables since 24.05.2010
what u have to do. first u must have an unstable image of 24.05.2010 or newer.
u can install rytec epg via softwaremanager or install it via telnet/ssh with following command
opkg install enigma2-plugin-extensions-xmltvimport
now it is installed. u dont have to put rytec.sources.xml in /etc/epgimport. they are allready there.
after these steps u have to restart e2 (which means gui restart). now press the blue button -> EPGImport. here u can select how many days u want epg and more. if u are in the "EPG Import Configuration" press blue button (sources). there u can select your epg channels by pressing "OK". after u selected your epg-data press the green button. now you are back in the "EPG Import Configuration". when u are finished press green button and he should load your epg. u should restart enigma2 again and take a look in the epg import again if he saved all your choices.
in some small tests it works great.
please remenber too much epg-data and plugins in flash (especially picons in flash) can kill your box.
Rytec.be epg is already installed for Newnigma2 unstable snapshot images from 24.05.2010 and newer.
The daily snapshots can be found here: http://feed.newnigma2.to/unstable/images/
Palautetta voi lähettää Huoltovalikkoon tai suoraan Newigman foorumille http://www.newnigma2.to/wbb2/thread.php?threadid=7258
