PLi® Helenite 500, 600, 56*0, 7000, 7020
The Original PLi® Helenite suite includes the following components:
Enigma 26-03-2007
Latest Dreamfiles and Dreamdrivers
Tuxtxt v1.99
Web Interface: 5.9.7-Expert - PLi edition
The Original PLi® Helenite suite contains the following images:
PLi®-Helenite-DM500-20070417-2696
PLi®-Helenite-DM56x0-20070417-2696
PLi®-Helenite-DM600-20070417-2696
PLi®-Helenite-DM7000-20070417-2696
PLi®-Helenite-DM7020-20070417-2696
Use the download URL below to be sure to download our original PLi® images.
PLi® Helenite images
See below for whats New, Fixed & Features
Kernel:
- Enable kernel nfs server for dm7000/7020 (FAQ will be available later)
Enigma:
- Complete new Enigma menu with complete new menus.
- Integrated PLi image setup into the new Enigma menu
- Fixed HDD/CF detection on dm7020
- Get skin now/next from EPGcache (till EIT arrives)
- Show skin streaminfo again in filemode
- Improved movieplayer performance and stability
- Auto audiotrack selection now avoids AC3, if AC3 not preferred
- 7020 and 600: Added possibility to reboot in **STOP** mode, from 'software update' menu
Mount manager:
- Mount manger is now a dynamic list and stays active all time
- Webinterface only shows defined mounts and has an ADD button again
- OSD interface shows mount status
- OSD interface mount/unount is one button with function depending on mount status
- OSD interface has new button to create a new mountpoint
- Added network mounts in file mode screen
- Added network mounts in several setup screens
- Added network mounts in webif/movie menu
- Made network mounts less picky for trailing slashes
Multiepg:
- Add EPG category coloring
Timezones:
- Update timezone info to 2007c
- First look in /var/etc/for a timezone.xml file
- Also check in /var/share/timezone for timezone files
- This way users can update/add timezone files themselfes
Multimedia:
- MPG/MP3 playback: fixed most crashes and hickups
- Support for RRAS (german channels SWR3, Das Ding & Cont.ra)
Startup:
- Improved network mount process during boot
DBEPG plugin:
- Use enigma epg database locations
- Remove datafiles after importing them
Log/Debuging:
- Add timestamps to all enigma debug/warning messages
Fixes:
- Motorsetup was not always possible
- Mounting after formatting was not always correct
- Mountmgr in OSD was not always showing correct info
- EPG storage location
- Webif EPG screens for foreign characters
- Ipkg install in Setup plugin
- CF card detection in multiboot
- Preferred audio language setup (matches also part of the audio name)
- Czech preferred audio for Czech Link
Changes:
- Cifs v1.45
- Recordings.epl can now be shared by multiple boxes
- Due to the changes for recordings.epl the web call reloadRecordings is now obsolete
- Parental lock has been changed
- Pin code check can be valid for x time so user won't have to enter pin each time
- Pin check can be disabled for x time after x times invalid pin entered
- Pin of 0000 is now also valid, let the user decide what pin he wants
- Mount.conf has been changed, therefore it is not always compatible to previous versions
- Mountnames in /mnt have been changed
- Now obey the setting 'Timer stop offset' also when pressing record button second time to schedule duration or stoptime on current recording
- LCD display does not show seconds anymore
- Optimize radiotimes (db_epg) script
- Added ftpput/ftpget
- Dm7020: Support swapfile on mounted device (mount first, then swapon)
- NA (E)EPG: some minor fixes
- Optimalisations for the Webstream2DB plugin
- Updated Dutch translations
Known issues:
- German and Frisian languages are not up to date
- When network share servers are unavailable booting the dreambox may take quite long or amy not seem to boot at all.
Many low level changes fixes and other updates...
Detailed info, FAQ's, HowTo's and TechNotes can be found on the PLi® Website:
http://www.pli-images.org
Thanks
ipela
ipela
nano7
Ypäjä
legenda
MrEre
MrEre
