Persian HD Project For VuPlus Duo HD By Persian Prince (OE 1.6)
There Is No Way For Upgrade From Previous Versions !
So Many Changes , Just Try It
It's Just For VuPlus Duo HD , Do Not Install It On Any Other Boxes
What Is Unleash Official ?
It's A Converter
It Will Convert Your Official Image To Persian HD Project Image
So You Can Use PPanel With Compatible Emulators Like CCcam
What Should You Do ?
1- You Need To Have A VuPlus Duo Image In Your Box (Inside) Flash
You Can Install Black Hole , Then You Need A Plugin For MultiBoot
You Can Use MeoBoot , It's Compatible With Black Hole
And ... You Need To MultiBoot Your VuPlus Duo HD With
Latest DreamBox 8000 HD Official Image
09-03-2011 Tested
DM8000HD :
http://www.dreamboxupdate.com/opendr...dm8000/images/
2- Install Unleash Official Plugin , Do Restart GUI
You Can Install It Via Menu->Setup->Software management->Install local extension
3- Go To Menu->Plugins Then Select Unleash Official
4- You Should Wait For A While , It Depends On You Internet Speed (8 Stages)
5- At Last You Will See A New Look , Restart
6- Enjoy
Hold Yellow Button For PPanel
Download Link :
http://www.sat-universe.com/showpost...67&postcount=5
It's A Converter
09-03-2011 Tested
DM8000HD :
6- Enjoy
Download Link :
