No, mikäs hitto se tämä on?????
DreamBox DM7000-S - Europasæt
Xtreme" ONE U2CI PVR Ready, Ny super modtager med indbygget "MAGIC CHIP"
Den nye Xtreme 9000 PVR Ready modtager har mulighed for Harddisk, der medfølger kabel og skruer til montering af HDD.
Model - U2CI PVR:
U = UCAS
CI = Common Interface Slot
PVR = Private Video Recorder
Der er:
2 x Common Interface
1 x Smartcard reader (MAGIC CHIP)(DREAMBOOT).
Der er Bl.a. Dansk menu & Danske undertekster.
Advanced AND stable: Xtreme" Quality Satellite Receivers with UCAS embedded solution.
Highlights:
- 256 Colors OSD & Convenient 2-layer GUI Architecture
- Intelligent Banner includes Channel Selection & Information View
- Teletext (with VBI insertion) / Subtitle function
- Ability to name or re-name satellites or channels
- Recall last viewed channel
- Parental lock facility by channel
- 8 event VCR timer function
- Programmable Sleep Timer
- Simultaneous Multiple Search with Satellites and Transponders
- High-Qualified Sensitivity of QPSK Tuner and Demodulator
- Dolby Digital Bitstream Out through S/PDIF
- DiSEqC 1.2 and USALS available
- SCPC & MCPC Receivable from C/Ku-Band and Wide/Universal-Band
- MPEG-2 Digital & fully DVB-S compliant
- Fast Auto-programming and User-friendly Installation
- Max 8058 Channels & max 60 Satellites(TV & Radio programmable)
- Useful Transponder Editing and Search
- Powerful Channel Control with Favourites, Lock, Move, Delete, Skip, Network, Satellite
- Signal Strength Display in Installation & Information View
- Powerful EPG using Now/Next and 7 Days
- Channel Sorting by A-Z,Z-A,Lock and by CAS
- Fast Channel Switching Time less than 1 Second
- Variable Aspect Ratio with 4:3 Letter-Box, 4:3 Full Screen and 16:9 (with SCART-ID)
- UCAS embedded solution
- DVB Common Interface with dual CAM slots
Teknisk
Specification:
Tuner:
- FEC Modes Rate 1/2, 2/3, 3/4, 5/6, 7/8
- Input Connector F Type female (75 Ohm)
- Frequency Range 950MHz - 2150Mhz
- Symbol Rate 2-45Mbaud
- Demodulation QPSK
RF Modulator:
- PLL type CH 21-69 for the modulation
- TV Standard PAL B/G, I, D/K NTSC M selectable
- RF Connector 75 Ohm, 169-2, Male/Female
- Frequency Range UHF: 470-860MHz
MPEG TS A/V Decoder:
- Video Resolution 720x576
- Input Bit Rate Max. 90Mbit/s
- Transport Stream MPEG-2 ISO/IEC 13818-1
- Audio Decoding MPEG/Musical Layer I and II
- Audio Mode Single / Dual Channel
A/V Data Input / Output:
- Video RCA/Cinch, Video Output (CVBS)/SCART/(CVBS,RGB) FCA/Cinch Volume & Mute Control
- Audio (Resolution: 20 bits DAC, Max 2Vrms)S/PDIF of Dolby Digital Bitstream Out
- RS-232C Transferrate 115Kbps, 9 PIN D-Sub Type
System Resources:
- Flash Memory 1 Mbyte
- SDRAM 8Mbtye
- Main CPU MPEG Chip STi 5518
Power Supply:
- Input Voltage AC 90 to 250V, 50/68Hz
- Power Consumption Max. 25W
- Protection Separate internal fuse
- Type SMPS
Pysical Specification:
- Size(w x h x d) 340 x 60 x 250 mm
- Net Weight approx 2.5kg (may vary depending on the version of the model)
- Operating Temperature 0° - 50° Celcius
- Storage Temperature -20° up to 60° Celcius
ja hintaa Tanskassa €572
HÖH???? Melkein kuin DB7000, mutta lihavoidut jutut ovat ainakin minulle ihan uutta asiaa.....
ja verkkoliitännän puute on m yöskin uutta.... mikähän juttu tämä oikein on? Tuohon aprillipäiväänkin on vielä reilusti aikaa.... :D
niin, joo:
http://www.videoogdatagruppen.dk/
Maija
pipox
Rekisteröimätön kävijä
