Newnigma2 v3.1.4
Newnigma2 team proudly presents:
Newnigma2 v3.1.4
Basics:
  • Enigma2 2.6: 22.01.11
  • Enigma2 Plugins 2.6: 22.01.11
  • Newnigma2 Plugins: 22.01.11
DM 800 HD se
  • driver: 15.12.2010
  • secondstage: 80
  • kernel 2.6.18
DM 800 HD PVR
  • secondstage: 76
  • kernel: 2.6.18
DM 8000 HD PVR
  • secondstage: 76
  • kernel: 2.6.18
DM 500 HD
  • secondstage: 80
  • kernel: 2.6.18
DM 7025(+)
  • driver: 08.12.2010
  • secondstage: 76
  • kernel 2.6.12
Changes:
  • Feature: EPGCacheSelector (choose the file and location of the epg cache file)
  • Feature: User can now decide if manual activated infobar should be hidden automatically (settings can be found in system settings)
  • Feature: Installer checks now every x hours or on system startup for updates (settings can be found in system settings)
  • Feature: Devicemanager internal routines changed from hotplug to udev netlink
  • Feature: Now with slovakian translation on feed.
  • Feature: Oled now with number of the currently running channel and improved layout
  • Feature: Simplified picon installation
  • Bugfix: camd menu, camd list wasn't visible sometimes
  • Bugfix: systeminfo crashes in some strange cases
  • Bugfix: dvd speed settings have not an affect
  • Bugfix: dvdhandling improved
  • Bugfix: menu -> plugins (german: erweiterungen) now linked to our onlineinstaller
  • Bugfix: large file support for FAT32 (now its possible to create partitions and files >1GB)
  • Bugfix: dvdbackup .iso image creation
  • Update: nl, lt and fr translations updated
  • Update: dvdread and dvdnav updated
  • Update: satellites.xml by Reinh@rd 15.01.2011
  • Update: dosfstools to 3.0.11
  • Added: enigma2-plugin-extensions-easymedia to feed
  • Added: enigma2-plugin-extensions-fancontrol2 to feed
  • Added: enigma2-plugin-extensions-reconstructapsc to feed
  • Added: enigma2-plugin-extensions-seekbar to feed
  • Removed: dvdburn and depends removed from image (dm8000). Saves 8MB flash
Infos for skinners:
  • You don't have to use skindir/newnigma2 folder for icons, they are now integrated. If you want to use your own png's, dont delete this folder in your skin
  • extInfoBarSkins.xml is removed. Dont use this file anymore, it is no longer available, but you can activate the ecm info screen still via osd preferences
Multiboot: No support for multiboot. Not planned. No need for such a tool.
G3wizard: No support for g3wizard. Probably not running. Not needed in Newnigma2 enviroment.
Onlineupdate from v3.1(.x) is possible.
Threads:
Your
Newnigma2 Team
PeeHoo
Espoo
Y
PeeHoo
Espoo
pumo
Imatra
ibiza
Oulu
pumo
Imatra
PeeHoo
Espoo
PeeHoo
Espoo
ramo
Lumikki
Länsi Kanta-Häme
Vu+ SoloSE T2 OA 5.1
NUC5+ Kodi (18.8) Libre
RPi3B+ Kodi (19.4) Libre
Qnap NAS 412,431,1635
LG Oled 65" & LCD 40"
AV Yamaha RX-V375
Proson 5.1
ramo
Micci
Raisio
Kaapeli + T90
Vu+ Duo 4K SE (C+S2)
Sony KD-65A85
ramo
tappari
Vantaa
Antenniverkko:
Duo 4K SE
Duo2
Uno 4K SE
Ultimo 4K
Y
