NewNigma2 V2.4
NewNigma2 V2.4
Newnigma2 team proudly presents:
NewNigma² Version2.4
Basics:
  • Enigma2 2.6 status 20.03.2009
  • Enigma2 Plugins 2.6 status 20.03.2009
  • NewNigma² Plugins status 20.03.2009
DM 8000 HD PVR
  • drivers status 2009-03-17
  • secondstage 72
DM 800 HD PVR
  • drivers status 2009-03-10
  • secondstage 72
DM 7025+
  • drivers status 2009-02-06
  • secondstage 61
Changelogs:
7025/800/8000 openembedded update
  • udev *enhanced external device handling (usb)*
  • gstreamer update
  • kernel *because of implementing new secondstage and new drivers, there's now more memory available
7025/800/8000 NewNigma² plugin fixes
  • language adjustments
  • USBmanger * better handling because of udev*
  • some corrections at emu restart handling
  • swapmanager: new feature install swap on USB
  • some small corrections on installer
  • NEW version configsaver attention: this one is not compatible with the older versions!
  • keymapselector adjustment at keymap_neutrino_half.xml
  • now visible upper row at LCD screen standby - NewNigma2 (date/date of the week)
NewNigma² skins fixes
  • added merlinmp3player to the HD-skins
  • FIX color 'background' must be #aarrggbb or valid
  • FIX BeyondDreamsCVS "LocationBox" renamed to "MovieLocationBox"
  • added Kerni-HD1 and dreamTV-HD searchtext in networkbrowser
  • adjustments of HD-skins to new configsaver
  • increased dreamTV-HD installer menu
  • adjustments of dreamTV-HD cccam info to cccam-info_1.2
  • adjustents of Kerni-HD1 and dreamTV-HD for networkbrowser
NEW at the 7025/800/8000 feeds:
  • enigma2-plugin-systemplugins-commoninterfaceassignment *only 8k*
  • enigma2-plugin-extensions-dvdeject
  • enigma2-plugin-systemplugins-configurationbackup
  • udev
  • udev-utils
  • libvorbis
  • libogg0
  • python-eyed3
  • sqlite3
  • libsqlite3-0
  • python-pysqlite2
  • liboil
  • gst-plugin-mpegdemux
  • python-textutils
Attention:
Because of many modifications of 'gstreamer' this time an online update isn't possible, sorry. All models need to be reflashed.
Please note that the new configsaver is NOT compatible with older versions, so we recommend to back up your important files to your PC before flashing.
However, there is a second method for experienced users to save your current configuration: its possible to download & install the new NewNigma² ConfigSaver Plugin from unstable feed, make a backup of your settings and then install the Newnigma v2.4 and restore your settings with the latest NewNigma² ConfigSaver Plugin.
Newnigma² team wishes lots of fun with our NewNigma² Version2.4
500plus http://newnigma2.to/wbb2/jgs_db.php?action=download&download_id=51&sid=
800 http://newnigma2.to/wbb2/jgs_db.php?action=download&download_id=52&sid=
7025 http://newnigma2.to/wbb2/jgs_db.php?action=download&download_id=49&sid=
8000 http://newnigma2.to/wbb2/jgs_db.php?action=download&download_id=53&sid=
600 http://newnigma2.to/wbb2/jgs_db.php?action=download&download_id=50&sid=
Newnigma-v2.4 english infos pdf http://www.newnigma2.to/wbb2/attachment.php?attachmentid=3763
Hensu
Lappeenranta
Vu+ Duo2 kaapelissa OpenATV
realjobe
Hensu
Lappeenranta
realjobe
realjobe
Hensu
Lappeenranta
realjobe
Hensu
Lappeenranta
realjobe
Hensu
Lappeenranta
Hensu
Lappeenranta
Hensu
Lappeenranta
pokkis
