Release Notes:
Due to flash memory lack to lower models, some of the pre-installed LT-Addons are not in the image. Download what you want with caution in order not to be run out of memory to your receivers, or you will have to re-install from scratch.
Once again, i would like to remind to all our fans out there, that a new skin is NOT a new image, and a new image doesn't always have to carry a new skin!!!
Openembedded:
OE 2.0
Drivers:
dm800 20120518
dm500hd, dm800se, dm8000, dm7020hd 20120711
Secondstage:
dm500hd, dm800, dm800se, dm8000 #84
dm7020hd #86
Enigma2:
20120912
Enigma2-Plugins:
20120913 master
LT revision:
3683
LT updates:
Removed LTDjMount and LTUshare plugins. (uShare and djmount does not exist
in OE 2.0 since uPnP is now part of Enigma2)
News in LTExternalEPG:
- Now using eTimer instead of crontab (No need to restart enigma2
enabling/disabling LTExternalEPG)
- Use <> in option "Grabbing Time" to start "EPG Timer Selection"
- Removed option "Grab every n days" (not needed anymore)
- New option to save log as xml (crashlog-like)
- Fixed bug where FATAL error didn't count grabbed channels correctly.
- New xmltv-grabber tvzon
- removed unavailable grabbers and grabber-configs
* dagenstv_no
* hallandsposten
* vg
* nova
* ambrosa
- updated grabber_db.xml.gz
Important note(s):
If you use ltlinks, be aware that the configuration file is now called lt9links.cfg and please start with a fresh one!
DM8000HD, DM7020HD, DM800se, DM800HD, DM500HD
Openembedded:
OE 2.0
Drivers:
dm800 20120518
Secondstage:
dm7020hd #86
Enigma2:
20120912
Enigma2-Plugins:
20120913 master
LT revision:
3683
LT updates:
* dagenstv_no
* hallandsposten
* vg
* nova
* ambrosa
Important note(s):
