Gemini 3.00: DB7000
Gemini 3.00: DB7000
Gemini v3.00:
* Enigma of: 21.06.2006
* Web Interface: 5.9.7-Expert
* Busybox 1.01
* Tuxtxt V1.98
* Own addon server via internet.
* AutoCam: Emu can be linked to channels/provider
* Cam settings: For example emu renaming, multichannel patch switchable ( >=7000 )
* OSD: EMM- and ECM- Display switchable
* Downloading and installation of additional features via Internet from Gemini server
* System Info: Many extra box infos (for example harddisk-temperature or all Enigma-settings)
* Download of Gemini news in background
* JPEGs can be rotated and the EXIF tags can be displayed ( >=7000 )
* Quick-Button-Menu: Many extra features for the yellow button
* smbmount
* Support for CDROM/DVD, no matter if IDE or USB port ( >=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted harddisk (only working if there is no harddisk inside,
mountpoint set to "/mnt/usb" and at least 3GB disk space)
* Extra Menu: Settings for many extras like Inadyn, HTTPD, EPG-Cache, swap-out of "/var" and many more
* Dreamnetcast: inclusive Shoutcast TOP(100)
* Background pictures for Radio, MP3 and SCAN can be changed via Blue Panel
* Own scripts can be started via Blue Panel
* Calender including reminder (can be changed via .../gemini_cal.conf)
* MVI's can be converted and tested (from JPG, BMP, GIF or PNG)
* Bootlogo for 7020 can be changed via menu
* New font and libfribidi for arabic language
* EPG for Dishnetwork
* 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
* Create your own Satellites.xml
* Dreambox can be used as printserver(BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Alarm clock with volume offset adjustable playing your own WAV-files.
* Display of current channel stream rates ( >=7000 )
* cifs-1.42b
* The image does now contain a useraddon.xml in /etc ml for 7020, /var/tuxbox/config for 500 to 7000 to enter an own addon server
which will be additionally displayed in BluePanel -> Addons -> Download. The file actually contains a example.
* multisocket second camd socket (cam1.socket) switchable.
Fix:
* New drivers rel1.10 (=7000)
* Attend CVS
Interfaces WebIF:
http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
We'd like to thank everybody who paricipated in the "Gemini suggestion" thread.
Unfortunatly many things can not be realized from our side.
This images doesn't contain any keys or softcams.
Backups or other modified Images are not from us
and won't be supported!
If you don't install the Image in flash memory, the flash image shouldn't be of a old version.
A swap file/partition (>= 16MB) should be present if several processes running in background.
http://www.dreamboxworld.com/dbw/main.htm
pokkis
Mibbi
sausage
pokkis
BMW
Lapland
Liitetiedostot
  • Bullz_Text_0.42.rar
    51 KB · Lukukerrat: 12
jpkokko
Hollola
Samsung UE55D8000 55" + LibreElec + Intel NUC-DN2820, nVidia Shield, Vu+ Solo4k & 1x 120cm motor dish + 1x 90cm2lnb, Vu+ Ultimo
JPA
Oulu
JPA
Oulu
jpkokko
Hollola
jpkokko
Hollola
pipox
Rekisteröimätön kävijä
jpkokko
Hollola
salde
Oulu
jpkokko
Hollola
