Dream Elite BH 1.3.3 OE1.6 DM800
Warning: Old plugins for OE 1.5 cannot work in OE 1.6, you have to ask to plugin authors to update. This is not an image problem. DON'T REPORT HERE FOR PLUGINS. WE ARE NOT PLUGINS AUTHORS
Warning2: THIS IMAGE HAVE THE NEW DRIVERS AND CANNOT BE INSTALLED IN MULTIBOOT USING PREVIUS IMAGES. THIS IMAGE HAVE TO BE INSTALLED IN FLASH
Warning3: AFTER IMAGE INSTALLATION GOTO DEVICES PANEL AND MAP YOUR DEVICES. REMEMBER TO INSTALL MEOBOOT ONLY AFTER YOU HAVE MAPPED YOUR DEVICES.
Warning4: ONCE YOU HAVE INSTALLED MEOBOOT DON'T MOVE DEVICE IN WICH MEOBOOT IS INSTALLED. (AS FOR EXAMPLE IF MEOBOOT IS INSTALLED ON USB DON'T REMAP THE DEVICE OF MEOBOOT ON USB2)
Warning5: YOU CAN INSTALL IN MULTIBOOT WITH THIS IMAGE ONLY IMAGES OE 1.6 WITH THE NEW KERNEL.
This image is a final Black Hole serie, to have maximum stability and performance.
We remember that black hole serie images have the best epg system available:
- Integrated Openepg for Sky-it Sky-uk Sky-Au
- Latest CVS enigma2 Epg features
- New external epg.dat system.
Therefore, each board or community can create its favourite EPG data files, and upload it to a web space. Community members can then download it from that server.
This feature offers additional benefits, such as:
EPG download increased speed
EPG download from any channel
EPG scheduled download also during standby
User set EPG Providers Add/Remove
WARNING: THIS IMAGE INCLUDE THE NEW KERNEL 2.6.18-7.3. FOR THIS REASON YOU HAVE TO INSTALL IN MULTIBOOT ONLY LATEST IMAGES BASED ON OE 1.6 WITH NEW KERNEL.
Main Function Keys
Blue Panel
Extra Setting
Black Hole Cron Manager
OSD Settings
Devices Manager
Kernel Modules Manager
Fast Plugin Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Black Hola Mount Wizard
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel
Info
CCcam Info
Service Info
Enigma2 Settings
About
Memory
Space
CPU
Process
AutoCam
Select EMU by Channel
EPG Panel
Global setting
Provider Setting
Green Panel
CCcam info
Fast Plugin
Addons
Addons Download Manager
Manual Install Del packages
Manual Install IPK packages
Addons Uninstall Panel
Dream Elite Statistics
Scripts
Many thanks to the Beta Testers Team.
Many thanks to Rytec for all the epg servers providing precompiled Epg.dat for Dream Elite Image (add skyIta and SkyDe).
Credits
Many Thanks to Rytec for external epg
Many thanks to Reinh@rd for the satellites.xml file.
SPECIAL THANKS TO ANGELOFSKY1980 AND DPEDDI FOR USB DVB-T DRIVERS
- USBTUNER REWROTE BY angelofsky1980 and PATCHED by dpeddi
- DE-API KERNEL PATCH BY dpeddi
ATTENTION!
http://www.dream-elite.net/forum/sh...-Elite-BH-1-3-3-OE1-6-DM800-Multiboot&p=22190
Dream Elite BH 1.3.3 OE1.6 DM800 Multiboot
WHAT IS NEW ?
New:Enigma2 CVS: Experimental 3 jun 2010
Drivers: 20100605
Seconstage: 76
New Bootlogo By Army
New Skin By Matrix10 Beyonce FantasyNew Check for correct image in flash
New Dream Elite own pathed kernel
New Usb Tuner Panel for drivers download
New Boot logo by Army
Main Function Keys
Button 1xOK = Light Info Skin
Button 2xOK = Extra Info Skin
Button Blue = Dream ELite Blue Panel
Button 1x Blue + 1x Red = Dream Elite Epg Panel
Button 1x Blue + 1x Yellow = New System Monitor Panel
Button Green = Dream Elite Green Panel
Button 1x Green + 1x Red = CCcam Info
Button Yellow = Time Shift
AddonsButton 2xOK = Extra Info Skin
Dedicated Addons Server
Download and install additional packages from Dream Elite server
Infobar/OSD Download and install additional packages from Dream Elite server
Enigma2 Analogic Clock
Channel Orbital Position
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
Advanced EMU information
Dream Elite Panels featuresChannel Orbital Position
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
Blue Panel
Extra Setting
OSD Settings
Devices Manager
Inadyn Settings
Swap File Settings
Hard Disk Setup
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel
Info
CCcam Info
Service Info
Enigma2 Settings
About
Memory
Space
CPU
Process
AutoCam
EPG Panel
Global setting
Provider Setting
Green Panel
CCcam info
Fast Plugin
Addons
Scripts
Credits
ATTENTION!
THIS IMAGE HAVE TO BE INSTALLED IN FLASH.
THIS IMAGE CANNOT WORK IN MULTIBOOT WITH DIFFERENT IMAGES IN FLASH.
STARTING FROM THIS VERSION DREAM-ELITE IMAGES HAVE AN OWN PATCHED KERNEL VERSION WITH A CHECK FOR THE CORRECT IMAGE IN FLASH.
Known bugs:
Hdd temperature is not working in OE 1.6 and the result is unpredictable
Backups or other modified Images are not supported!
