DaVinci 5.5 final 7000
Status
Viestiketju on suljettu, uusia vastauksia ei voi lisätä.
The Satnews Dreambox Team
SDT DaVinci 5.5 FINAL
- Kernel and modules 2.6.9 (1_09.1d)
- Enigma compiled 06/05/2006 - CVS modified by SDTeam
- WebIf 5.9.7-expert
- TuxTxt 1.98 (teletext)
- Movieplayer 0.8.1
- SDTboss Panel v2.6.7
- emuboss v2.9.5 (emumanager)
- Skins: 3 included, in 5 versions
Mimi_74 animated compact 4:3/16:9 (default)
Mimi_74 animated extended 4:3/16:9
Eagle Megalight 1.2
WHAT IS NEW:
- Support for an alternate Remote Control (!! new !!):
On DaVinci 5.5 you can select the keymapping for "Philips Pronto" or another compatible programmable remote control.
This is an absolutely innovative option, never seen on any other image before!!
- ECM Display on OSD:
Yellow, if encrypion is present (emm)
Green, if it is used for decoding (ecm)
- Decoding source display on OSD (card / emu / network)
- Added Betacrypt to known encryptions icons, displayed on OSD for ecm and emm
- Camd3:
added caInfo as default item when SDT Advanced Infos window displays.
- Gbox:
added SC item on SDT Advanced Infos window, displays full infos on inserted sc.
- Skins:
Added latest Mimi "Anim 5.5" compact/extended 4:3/16:9, and Eagle's Megalight 1.2
- Locales:
Added updated Italian and French translations
- A/V Settings shortcut:
Added very useful shortcut to "Audio/Video Setup" window in BOSS Panel's "Extra Setup" (3x Blue Key)
- EPG Wizard:
updated default download channel to "SKY Assist"
AND....
bugfixes and other improvements!
Enjoy!
http://www.satnews.tv.it/ricevitori/dreambox/firmware/SDT/DaVinci_5.5_FINAL.zip
arnold
Y
crashi
pumo
Imatra
pumo
Imatra
Status
