quibath
BlackHole Vu+ Duo v. 1.5 Multituner
WHAT'S NEW? Tikkua pers..koneeseen
NEW NEW NEW: Dual Usb - Tuner support !!
Black Hole image is the first enigma2 firmware that support two usb tuner.
Black Hole image support:
Single Usb stick dual tuner
- Two Usb Tuner sticks same model
-Two Usb Tuner sticks different models
WARNING:
The new 1.5 series Black Hole images skins are not compatible with above skin versions
WARNING:
Black Hole can not support images not installed in the flash.
- Integrated OpenEpg
Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Enigma2
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Manager Kernel Modules (Kernel module operator)
Black Hole Mount Wizard (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
Usb Tuner Panel
Info Panel
1 - E2 Setting (Enigma2 configurations)
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Addon Download Manager (Manager for package downloading)
Installation manual packages (Manual installation of Black Hole packages)
Crediits
Thanks to bigroma (vuplus-community board) for rt3070 patches.
WARNING:
WARNING:
Addons
Infobar / OSD
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Usb Tuner Panel
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Crediits
