Black Hole Vu+ Solo2 1.7.9-* (Transcoding)
1) New drivers: 20121217
- Fix instability issue(needs kernel update)
- Fix PIP problem
- Fix module init problem.
- Support Transcoding(Beta)
2) Add trasnscoding streaming plugin(e2), and client(transtreamproxy)
3)Adjust kernel config
4) Various fix on Udb Dtt drivers
5) Ubdate Usbtuner
About Transcoding (Thx to Ev0 for tests):
transcoding function has been tested anf working with WebInterface and Ipad.
It work from inside and outside of home network, so also does work over the internet with the correct ports open. It also works via 3g (although this obviously isn't perfect).
logonewblackhole-jpg.9774
WARNING: This Image is not compatible with the previous skins
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.
The image MUST be installed in the flash.
Black Hole can not support images not installed in the flash.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red short press= access HbbTv functions
Button Red long press= Red Panel (Parallel Universes Teleportation)
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Installation manual packages (Manual installation of Black Hole packages)
Red Panel
BH Parallel Universe Teleportation
Black Hole
Avalon
Chaos
Ghost
Credits
Thanks to Pedro_Newbie for Backup script
Thanks to ambrosa (Pli Board) for ready-to-go A867 driver patch
http://www.vuplus-community.net/board/threads/black-hole-vu-solo2-1-7-9-2-transcoding.10136/
  • Kiitos
Reactions: CKN
