mustis55
- VU+ Ultimo 4K (FBC Dual DVB-S2X x 2 + dual T2)
2x duo2 (dual S2 ja dual T2) ja VU+ Duo (2xS2 + 2x ulk T2)
2 x Triax TD 110 DL
1 x moteck SG-2100A
OpenVix
Black Hole Vu+ Duo 1.7.2 (media-tree)
The Black Hole 1.7.2 is the most "stable" and fast version of 3.1.1 releases.
Based on Offilcial Vuplus image 7.0
Kernel: 3.1.1
Vuplus drivers: 20120126
Vuplus DvbApp: 20120204
MeoBoot: 1.0
Skin: Army MooD HD updated
NEW NEW NEW: Next generation Usb Tuner Drivers (media-tree bh build)
Wifi drivers: rt3070 driver updated with some BH patches
Fixed: Prevent crashes in plugins using infobar (double ok crash)
Fixed: Vuplus WirelessLanSetup bug (Cannot generate Passphrase)
Changelog Vu+ drivers: clean & speed up dmx driver
Add gstreamer plugin fragmented
Kernel: add igmp.patch
Fix serviecmp3 bug: stop response timeout when stream is HLS.
Fix youtube player of webbrowser launcher plugin: add code to select stream quality.
NetworkSetup.py : fix checkNetworkCB function to prevent crash error
HDMICEC : fix default device name
Vuplus Event : input 7 SN_b for MSA
Webbrowser: fix build bug.
Changelog about USB DVB & Wifi Devices:
- changed all set of DVB USB drivers: now with BH image there are the latest drivers avaiable
- USBTuner 0.3.9: a lot of bugfixes to improve stability and performances
- Wifi (RT3070): applied some extra patches to Vu+ driver to improove dongle functions
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.
The image MUST be installed in the flash.
Black Hole can not support images not installed in the flash.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Installation manual packages (Manual installation of Black Hole packages)
Credits
Thanks to Pedro_Newbie for Backup script
Thanks to ambrosa (Pli Board) for ready-to-go A867 driver patch
DISCLAIMER
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
THE BLACK HOLE IMAGE IS ISSUED FOR THE FREE USE FOR ALL USERS PROVIDED THAT IT WILL NOT BE CHANGED IN ANY WAY AND THAT IT WILL ONLY BE USED FOR LAWFUL PURPOSES.
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REVOKE OF THIS LICENSE.
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.
