Black Hole 1.7.6
Black Hole Vu+ Duo 1.7.6
What's New
New Green Panel Setup
- Customize the plugin list. You can now assign a progressive position number to plugins.
New drivers Vu+ drivers 20120628
- Improve vtuner performance
- Support 2 zapping mode(hold, mute)
- Optimize memory usage in demux driver
- Change dual tuner locking mode
- Support streaming interface(Remote Channel Stream Converter)
- Support H/W Graphic2D acceleration for HBBTV
- Fix incorrect VFD display(duo, uno)
New Skin Army TranSpaRency HD
- Awesome skin with low graphic impact. Another little masterpiece of our master Army.
New Plugin AddStreamUrl
New Plugin ZappingModeSelection
Add support http ts stream.(client)
Disable hdmicec plugin' for default
Load Bouquets' support for non dvb services.
adjust kernel config for size reduction
WirelessLanSetup : fix bug (AP's protocol info is None)
StreamTv plugin: fix bug.
WirelessLanSetup : If wireless lan module is activated, do checkIfaceMode
logonewblackhole-jpg.7942
osd1-jpg.7943
osd2-jpg.7944
plugin-jpg.7945
green-jpg.7967
grenn2-jpg.7968
plugin1-jpg.7946
plugin2-jpg.7947
common-jpg.7948
extrasetting-jpg.7949
WARNING: This Image is not compatible with the previous skins
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.
The image MUST be installed in the flash.
Black Hole can not support images not installed in the flash.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Red Panel (Parallel Universes Teleportation)
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Installation manual packages (Manual installation of Black Hole packages)
Red Panel
BH Parallel Universe Teleportation
Black Hole
Avalon
Chaos
Ghost
Credits
Thanks to Pedro_Newbie for Backup script
Thanks to ambrosa (Pli Board) for ready-to-go A867 driver patch
Black Hole Vu+ Ultimo 1.7.6 HERE
Black Hole Vu+ Uno 1.7.6 HERE
Black Hole Vu+ Duo 1.7.6 HERE
Black Hole Vu+ Solo 1.7.6 HERE
paavoxxx
Hexi
mustis55
VU+ Ultimo 4K (FBC Dual DVB-S2X x 2 + dual T2)
2x duo2 (dual S2 ja dual T2) ja VU+ Duo (2xS2 + 2x ulk T2)
2 x Triax TD 110 DL
1 x moteck SG-2100A
OpenVix
