DreamBoxEdit IHAD Edition
Hurjaa kehitystä DreamBoxEdit-IHAD Editionissa.
Download | dreamboxEDIT
Changelog:
3.0.1.1
- fixed network timeout issue when IP address is not reachable
- fixed editing and saving of negative AC3 and PCM delays
(note: you have to delete all extra parameters in the detail panel if you have entered any delay values before)
- fixed error message after saving and opening new settings
- added customizable row color
- new window and button styles
- all message dialog buttons were german, message dialogs can't be translated, changed locale to English
3.0.1.0
- added display of currently active service on your dreambox (enigma2 only)
- added volume control (enigma2 only)
- added malti language file, other language files updated
- fixed error message when comparing loaded services with services on dreambox/disk
- added button for special services (service types 130, 133 and 211) in the options panel
(you need a patched Channelselection.py to make this channels visible on Enigma2)
- added service type 10 to standard radio types
- small GUI changes
3.0.0.6
- disabled SatcoDX import/export as this feature is deprecated, website of SatcoDX is down
- improved servicename filter, now it matches all services, the old one missed some (e.g. RTL Television on 19.2°E)
- sorting of columns with drag&drop is now possible (no saving at the moment)
- fixed update check
- added column for DVB-system
- added column for modulation (now it's possible to remove all DVB-S2 transponders after conversion from E2 to E1 very easily)
3.0.0.5
- removed settings-type 3 from options panel (no longer needed all E2-Boxes working with settings-type 4)
- added button with terrestrial path settings (E1) to options panel
- fixed settings-type switching via menu -> tools -> toggle between version 2 and 4 settings
- added language files (crnogorski, czech, dansk, espanol, francais, greek, hrvatski, italiano, magyar,
nederlands, norsk, polish, russian, srpski, svenska, turkce, ukrainian)
- added language tool for translations (you can find it in the installation folder),
please send me your language file updates on the support forum, thanks!
3.0.0.4
- fixed error message after enigma2 settings reload
- servicename filter added
3.0.0.3
- fixed scrollbar issue
3.0.0.2:
- restored zap function for enigma2
- changed menu bar icons
3.0.0.1:
- fixed FEC values for DVB-S/DVB-S2 modes
- restored satellites.xml editor function
Changelog:
3.0.1.1
3.0.1.0
- small GUI changes
3.0.0.6
3.0.0.5
3.0.0.4
3.0.0.3
3.0.0.2:
3.0.0.1:
