Nemesis v 2.0 DM 7000+7020+500+600+5620
chaoscreator
Kemiönsaari
Löytyy kaikille DM koneille mutta ei 7025:lle
Tässä DM 7000 speksit:
* Enigma of: 20.09.2007 (fix Gianathem)
* Linux version 2.6.9
* GCC 3.4.4 Original CVS 1.1.0
* Web Interface: 6.0.3-Expert
* Dreambox driver v. 02-04-2007
* Busybox 1.01
* Tuxtxt v. 1.99
For use in FLASH or multiboot in USB, NFS, CF
* BLUE - Nemesis Panel
* BLUE > 1s - ECM INFO, EMM INFO e PID INFO
* 2x BLUE - Addons
* YELLOW – Plugins
* YELLOW > 1s – *** - CS Info
* GREEN – subservices
* GREEN > 1s – EPG Control Center
* 2x RED - EPG style menu(Included epgui, MvEPG, WeekEPG you do install it to activate a function)
* Nemesis *** Manager 2.0.0
* Nemesis *** Manager in italian & English
* Independent Start & Stop *** / CARDSERVER
* Advanced Inadyn service configuration, with log manager
* Swap file configuration, you can set swap in USB, CF or HDD
* Move /var in USB, CF or HDD
* Path manager panel
- Setting PVR Movie folder
- Setting Picon folder
* Iptables/Firewall Panel
- Start/Stop firewall
- Firewall configuration
- You can add/remove yours rules directly from panel
* Picon support included in Enigma
- You do install only Picon Images from blue Panel
- You can install Picon images in FLASH, USB, CF or HDD
* Syslog panel
- Start/Stop syslog daemon
- Syslog configuration
- Debugging enigma directly to syslog, no reboot needed!
* EPG Control Center Panel
- You can download and store, manually or scheduled, EPG data for:
- Enigma EPG Cache
- MvEPG
- WeekEPG
- epgui
- Please install the plugin only from Nemesis addons by blue panel
- You can find a guide in our forum
* Autostandby/autoshutdown (to manage a unwanted reboot)
* Advanced external programs control
* Can start / stop your own binary by panel (see /var/etc/sample_startup.sh)
* Can create your own autostart boot script (see /var/etc/sample_startup.sh)
* Support for sigboost, gSUB via advanced external programs control
* Advanced User Script
* Can run script in kernel mode
* Automount (see /var/script/mount.sh)
* Advanced System info (see /var/etc/script.xml)
* Advanced *** info (see /var/etc/emuscript.xml)
* Advanced HardDisk setup
* Parental control shortcut
* Nemsis news
* MediaHighwayEpg
* emm, ecm support
Display Function:
* New Skin Nemesis Advanced by DDAAXX
* Skin Lite on Change Channel
* Skin Lite on Button OK press
* Display Snr, Agc, Ber
* Display video info
* Display frequency, polarization, symbol rate
* Display *** in use
* Display service providers name
* Display CaID, ProvID, PID
* Display Decoding Source (you can hide if you want)
* Display DC as IRDETO in OSD
* Display long date format
* Web-if and other graphics content modified (by DDAAXX)
Addons:
* Advanced addons Manager
* Internet addons download with Proxy support
* Manual addons install
* Remove installed addons
Misc:
* Italian, English language
* Many language in download
* Extended Busybox command
* Extended libc
* Extended libcurl
* libfx included
* Support modules for openvpn (tun.ko) included
No keys, No *** included
Löytyy:
http://www.genesi-project.it/nemesis/index.php?dir=Nemesis_Image_2.0/
tai
http://www.genesi-project.it/forum/index.php?&&CODE=00
VU+ Duo 4k lite, Duo4kse, Samsung 4k 75", AppleTV
