aints
- Vantaa
- AX HD61 GigaBlue Trio 4K 2x amazon firestick 4K max, 2x nvidia shield pro
Ferguson Ariva 4K Combo SAT+TDT2, WiFi Dual, Android 5.1
Ariva 4K Combo is truly a multimedia receiver! This is a response to the multimedia needs of the present day and tomorrow.
Main features:
4K UHD - Support for ultra-high resolutions
H.265/HEVC - Support for hardware decoding
DVB-S2 - H.264 Full HD 1080P TV
DVB-T/T2 - also support for H.265/HEVC standard
DVB-C - Cable television
Support for pay TV card reader (CA)
Dualband Wi-Fi - 802.11 b/g/n 2.4Ghz/5Ghz
Ethernet modem (LAN) for interactive communication with local network and Internet
Bluetooth - Support for connecting the keyboard and mouse or other devices
SD Card Reader
Hard drive ready - Support for easy hard drive installation for TimeShift and programs recording
Android 5.1.1 Lollipop
Kodi Media Center - Advanced multimedia support
Netflix, HBO GO - Excellent cooperation with almost all Video On Demand (VOD) services
DLNA, Miracast i AirPlay - Support for media streaming to the device
Technical Specifications
Chipset: Amlogic S905-B, Quad core Cortex A53 @ 2.02 GHz
Flash Memory: EMMC 8GB
DDR III Memory: 1GB
DVBS Tuner Type: On board
DVBS Frequency Range: 950~2150MHz
DVBS Demodulator Mode: DVB-S (QPSK, ETS 300 421) and DVB-S2 (QPSK/8PSK, ETS 302 307)
DVBT/T2/C Demodulator Mode: ETSI EN 302-755 V1.3.1 and EN 300-744 V1.6.1 compliant
DVBT/T2/C Frequency Range: 52.5MHz to 866MHz
Video Decode:
H.264/H.265 HEVC MP L5.0 up to 4K UHD 60fps
H.264/H.265 AVC MP L5.1 up to 4K UHD 60fps
H.264/H.265 MVC up to 4K UHD 60fps
MPEG-4 ASP L5 up to 1080P 60fps
AVS Jizhun Profile up to 1080P 60fps
MPEG-2 MP HL up to 1080P 60fps
MPEG-1 MP HL up to 1080P 60fps
RealVideo 8/9/10 up to 1080P 60fps
WebM up to VGA
Video File Format Support: MKV, WMV, MPG, MPEG, DAT, AVI, MOV, ISO, MP4, RM, JPG, BMP, GIF and others
HDMI Output: HDMI 2.0
Video Resolution: 4K 60Hz, 4K 50Hz, 1080p/i, 720p
Wi-Fi: Built-in 802.11 b/g/n, 2.4G/5G dual band
Ethernet: Bilt-in 100M Ethernet RJ-45 modem for communication with Internet network
Audio Decode: Dolby Digital/Digital Plus, MPEG, OGG, OGA, FLAC, ALAC, APE, M4A, RM, MPEG-1 layer1/2, MPEG-2 Layer II (DTS passthrough)
Sampling Frequency: 32KHz, 44.1KHz, 48KHz
PVR Record: Instant Record and Timer Record, EPG Timer Record
Time-Shift Support: Auto Time-Shift
File System Support: NTFS, FAT32
Operating Temperature: 0°C-40°C
Storage Temperature: -10°C-65°C
Humidity: <95%
Dimension (width x depth x height): 258mm x 158mm x 43mm
Input Voltage: 12V 2.0A
Power Consumption: Max 24W
Power Consumption in Standby Mode: <0,5W
Main features:
SD Card Reader
DDR III Memory: 1GB
Video Decode:
WebM up to VGA
Humidity: <95%
