EVO-MINI-ufs910-e2-3p1-1548-FLASHSUITE_GoForIt
Onko kukaan kerennyt koittaa tätä?
WHAT IS EVO-MINI:
THEREIN IS THE SO-CALLED BY MINIUBOOT "solala (FAT THX AGAIN) INCLUDED!
SO IT IS POSSIBLE VIA RC BOAT ON HIS IMG CHOOSE WHAT IS STARTING TO, WHETHER FLASH, USB OR NFS!
THIS SHOULD BE MADE ONLY IN THE bootargs FLASHUITE IN 3P1MINI.TXT ADJUST AND THE EVO *. IMG DEPOSITED IN FLASH SUITE FOLDER.
THERE ARE POSSIBLE ENTRIES FROM 0-9! (GO TO CONFORM. TXT FILE)
THEREIN BEFORE BOOTARGSÜBERTRAG AND ONLY VERY UP YOUR IP, GW, ServerIP, NETMASK
ADAPTED FROM YOU ARE ALREADY CAN Flash and ARGS TRANSFERRED, AND EVEN THEN it boots DIRECTLY FROM WHERE TO FLASH VIA JICH RC CHOOSES WHAT ELSE! Bootargs EXTENSIONS FOR EITHER THE EVO IMG FW_SETENV STOP THE USE OR TXT MODIFY AND AGAIN TRANSFERRED.
OBIS INSTRUCTIONS FOR VARIOUS WAYS TO FIND UNDER "INSTRUCTIONS" HERE AT THE BOARD!
new in mini1.1-final:
emerg is back, it can now flash if the mini is back to normal from usb flash stick.
give you more information in the download thread to the mini-1.1-final here
who is already a mini-evo-img in flash can also have the mini-1.1-final preliminary "flash" to flash then the evo-mini-1548.img as in the mini-thread explains via usb-stick to then!
it simply an old evo-mini can (eg boot 1501) and the copy miniUPDATE.img by means of ftp / tmp ufs, but kill only after:
telnet: Quote:
killall -9 rcS
killall -9 enigma2
Now after mini tmp directory via ftp and then:
Code:
dd if = / tmp / miniUPDATE.img of = / dev/mtdblock5
HOW IS THE ONLY IF YOU ALREADY TOLD DE EVO IMG WITH MINI IN reflashing Did!
then after that is also this:
Quote:
direktes Flashen mit mini:
wenn man auf nem USBstick oder auf interner SATA oder auf nem TFTPserver ein full-image
mit namen:
miniFLASH.img
evo1548_usb_test3 entpacken und *.img so umbenennen!!!)
ablegt (Größe 15,8MB) und beim Boxstart die REC-taste ca. 3 sek gedrückt hält (bis "miniFLASH search" im Display erscheint), dann wird das miniFLASH.img in den Medien gesucht. Sobald es gefunden wird, wird es geladen und geflasht. FAT32 oder ext2 ist dabei auf dem Stick egal... miniFLASH.img muß nur im Stammverzeichnis der ERSTEN Partition liegen, also auf USB 0:1 oder IDE 0:1.
WHAT IS EVO-MINI:
telnet: Quote:
killall -9 rcS
killall -9 enigma2
Code:
mit namen:
miniFLASH.img
