AAF Weihnachtsimage UFS910 Flash
http://www.aaf-board.com/wbb2/thread.php?threadid=36456&sid=bbaf2a97ede7a62ee98563e7c57c33f6
Image Info
AAF USB Weihnachtsimage für Kathrein UFS-910
Basis Team Ducktales Build rev1853 vom 13.12.2009
(letztes TDT release vor Open Source Projekt)
Changelog seit letzten oeffentlichen Release:
Aenderungen seit E2 rev1711 / AAF Indian Summer BA Image V2
Team Ducktales:
+ gotosleep durch fp_control ersetzt
+ MP3 Playback etwas stabiler
+ DTS Fix
+ Kernel Optimierungen
AAF Panel 7.7
AAF:
+ AAF Panel 7.6 (added VideoTune | several fixes and updates)
+ Volume Adjust (menu -> settings -> VolumeAdjust)
+ Cleanup Wizard (menu -> settings -> system ->...)
+ Crashlog Wizard (menu -> settings -> system ->...)
+ MediaCenter (IMDb Support | new Videplayer Filelist | WeatherPlugin | WebRadioFS)
+ miniuboot r1.3 update (for lzma compressed kernel, better compression and a littel more speed)
+ Repairmodus (when error or bootloop)
+ usbspeed (test usb storage speed)
+ mixed lzma/zlib compression for /var (better compression and a littel more speed)
+ usb-storage.usbwait123 kernelparameter (setting the boot sequence)
+ ntfs read/write support (you can aktivate this in aaf panel)
+ much fixes in samba server
+ only boot E2 on error (you can aktivate this in aaf panel)
+ new onlineflash tool (with verify and tv output)
+ new system layout (for more /var free)
+ partition load for problem storages (you can aktivate this in aaf panel)
+ some fixes in ramswap
+ wget, fsck, mkfs (precentage display on vfd and tv)
+ much other fixes
Bekannte Probleme:
- Manchmal nach dem Zappen kein Ton (Ton oder Kanal umschalten hilft)
- Nach längerem Betrieb kann es vorkommen das der Ton stottert(umschalten hilft)
Image Info
Team Ducktales:
+ DTS Fix
AAF Panel 7.7
AAF:
+ much other fixes
Bekannte Probleme:
